Gentlemen, I am looking for suggestions and some help.
I just put a FAST system on my 383 LT1 in my '93 f-body. The car previously had a custom eprom in it tuned by myself using Tuner Cat software. The car ran well (11.90's) even being forced to short shift it below the ceiling of the factory pcm. I wanted to getaway from having to burn chips and needed to break the 7000rpm ceiling of the factory ecm because of my high-reving valvetrain. The combo should be good for mid to low 11's.
I transcribed my previous VE and spark tables into the C-Com software and setup fuel calc parameters for my 383 w/ 30# injectors. The AE/TPS tables are setup quite different so I tried to go by examples listed on this forum to get them in the ballpark.
To say I'm struggling now would be an understatement.
Idle & cruise drivability is fine, very happy with that.
Slowly rolling the loud pedal into the upper rpm's seems ok as well, with an occasional miss above 5500rpm's.
Stomping it is a whole different story unfortunately... the car lunges off the line like an animal and pulls hard till it quickly hits 5500rpm, then it starts to miss. It will pull on through this up into the upper 6000's rpm's, missing and stumbling. It feels like the motor is trying to pull the car but something is holding it back. It is NOT too lean and I believe the problem is actually that I'm choking it with too much fuel on acceleration. I just don't know what tables and how to manipulate those tables to sort out this problem. I've been trying to get it right for days.
It always happens above 5500rpm, the faster you bring the rpms to 5500, the worse the problem is. Brrr-ba-bbr-ba-brrrr-brr-ba-brrrr. I'm hearing it in my sleep. ANY advice would be greatly appreciated. If anyone might be so kind as to like to take a look at my gct file i'll email it off to them.
