I have been having all sorts of issues with my FAST B2B w/WB02 ever since I installed it in my truck a couple years ago.  This year, it seems to have gotten worse.
The following is a brief summary of the issue; and I am soliciting advice on what to do next.
1/ Using the same versions of c-com wp on two different laptops changes the behavior of the truck if the laptop is plugged in. This is without uploading a new program to the ecu, just simply connecting it and bringing up the dashboard. One laptop produces terrible results (ie running really really lean, no idle, etc) while the other produces a much better idle, but quit rich (12.0 afr at idle).
2/ Without a laptop connected, the truck runs totally different each day I start it. One day, pig rich, the next (like today) way way way lean.
Data logging shows no issues at all with the battery voltage; the wideband appears to be working based on the dashboard information.... Grounds have been triple checked, etc. No vacuum leaks.
I am completely lost.
 Should I box it up and send it in for testing?
any help/advice is appreciated.
