FAST users, is there anything special you have to do in order to have the highspeed fan turn on? I have adjusted the fan temperature and the fan definitely kicks on, but it seems to be lo speed only...
Additionally prior to FAST installation the fan used to kick on after the car was shut off. Does this feature work with the FAST and if so does it require additional wiring? I am currently using a harness provided by Jack Cotton which turned my FAST system into a plug and play affair. Now it appears the delay feature is no longer working..
Suggestions??????
If the XFI doesn't control this, I suppose I could hook up an additional thermostat and allow the delay feature to be manually controlled..
Suggestions??????
