I've had it with this car! I'm ready to part-out this P.O.S. if I can't get it fixed soon....It's an 84GN...mostly stock. 90,000 miles. I bought several months ago from a "friend" (now an ex-friend) in Arizona. I live in Missouri now. It appeared to be in average condition for an 84. It didn't run too well, but I knew the turbo was bad. He said it just needed a new turbo and had run excellent before then.
I replaced the turbo late last summer right after I bought it... went with a stock turbo, except this one is water jacketed and has an adjustable wastegate. I noticed it didn't really idle any better & really ran like crap. I didn't mess with it much since I bought a new house. I decided a few months ago to tackle this project again. Now that you have the history, here's the symptoms:
Very rough idle, but doesn't die
Stumbles real bad off idle & often backfires (small) out the intake
Then it's OK at part throttle up to a point
The timing light shows it at 15deg @ idle. Jumps to 30deg once you rev it any.
Builds boost to 18# OK. Spools pretty quickly too.
Begins to misfire / light backfire (intake side) as RPM and throttle position increase.
I can go almost 100% throttle once past the off-idle stumble, but have to begin backing off the throttle fairly quickly as RPM's increase
Once up to 60+ MPH, I can't get it above 50% throttle or it misfires pretty bad.
I notice a puff of black smoke in the rear-view mirror when it misses.
Only one SES light ever. A few months ago I got a lean exhaust code, The car had been sitting at idle for 10 minutes or so. No other codes since.
Runs smooth only on cold starts when at high idle (2,000). Smooth for about 20 seconds, then the idle drops down to about 1,000 & it runs like crap from then on.
NOW... Here's what I've done:
New stock turbo.
New oil pump (cause of turbo failure)
New coil, wires, & plugs. (The old plugs read pretty rich to me) Gapped .040
Adjusted TPS (was way off), cleaned IAC
Checked fuel pressure - 35psi at idle & steady 40psi under load
Removed and cleaned injectors
New O2 sensor
New t-stat (had a 195deg in it)
New engine temp sensor
I was told the MAF was replaced just before I bought it (Geee... that shoulda been a clue... HUH?). I've tried unplugging it and the car will barely run. Then sets a MAF code OK.
Sprayed the hell out of it with starting fluid looking for vac leaks & luckily didn't burn the car to the ground. EGR not leaking.
Looked pretty hard under the dash for any broken vacuum lines
No noticeable exhaust leaks until after the catalytic converter (Shi@#y Midas exhaust job)
I don't have a scan tool
I've had this in to several shops. They all charge me 1/2 a week's paycheck to change some BS thing, say that's all it needed, but none have made it even slightly better. (One of them just cranked the idle up & called it good)
Any Suggestions?!?!? This car is really close to having an "unfortunate accident" and becoming an insurance claim. Heck! I'm ready to go buy a ricer I'm so P.O.'d
I guess I need to do a compression test to see if the cam is screwed. & get a vac guage hooked up. My gut feeling is a bad vacuum leak or an ignition problem. I'm just sick of spending money. I've already got almost twice what this car is worth into it.
New stock turbo.
New O2 sensor
