Fiberglass Hood?
F-1
Fiberglass Hood?
Who makes the best bolt on OEM looking hood.. I am looking to purchase one, but I want it to look as factory as it can..
Can you install a hood insulator on one?
Who makes the best one?
Where can you get it, who has the best deals?
Correct under hood detailing and framework?
Thanks,
Dave
i dont think glasstek is as correct as the hood that i had on my gn .......ive seen both up close and personal esp. the underhood stuff
the hood don't need all of the factory bracing because it is fiberglass. it is the best fiberglass hood available as they make doors and trunk lids. also i have seen other companies work and they cut corners on making ther product and glasstek don't.
dude you obviously dont know ALL of the fg vendors cause glasstek aint the best .......and also he WANTED stock appearing ......and there is oly one mfg that is totally stock appearing .........ive had both and there is no comparison.........
Thanks for your guys input... Idaho, which one are you refering to? I talked to Hartline Performace and they have about the closest one I have heard of.. It even has the rear trim molding molded in....
Thanks, Dave
dave,
cal has the hoods in your area ...........they have the best fit and finish and are totally stock appearing ......
Mine is a pin on but the fit and finish is remarkable, about a 3/16-1/4 gap all the way around.
http://www.vfnfiberglass.com/site.htm
and here's a pic of mine
