Today I broke down the block that I used to have in my car about a year ago, before it developed a knock.
Only sign of damage I could find was on the #1 rod journal. The rest of the crank looked good. I will have it looked at to verify. I wonder if I can use oversized bearings on just that one or do I need to have all turned? Dont know if .010 will clean it up or more is needed. Surface looks rough compared to the smoothness of the others. Weird, I think the bearings were moving around. The tabs on them that fit in the grooves on the rod and cap were gone.
Block is already .030 over and cylinders look good. Dont feel any ridge at top of cylinders, should be able to just hone them. Pistons are TRW forged and should still be fine. Rods looked good too. I will get 2nd opinions though. What rings do I need to get? Any special type? What about bearings? Or can I just get the rering kit from somewhere like Northern Auto Parts ($135) which comes with rings, rod/main bearings, and gasket set?
Had 204/214 SpeedPro (sealed power/federal mogul) cam. Didnt have very many miles on it at all before I pulled the block. Worked fine, idled great. There is a bit of surface rust in a couple spots now. Im still not the greatest at reading a bad cam so I will have it looked at. Dont know if it is actually starting to pit or not. Im kind of hoping that the cam is still good (not looking forward to breaking in another Buick cam). If it isnt good, Leeo already recommended the 208/224 Schneider. Does anyone know where to get this cam and how much does it cost? Any other cam suggestions? Didnt really get a good chance to see what I could do with the 204/214, maybe I just get another? [WANT TO BE ABLE TO MOVE SOME AIR
I have a Rollmaster double roller chain that I will use also. Very few miles on it also when the motor came out.
Shouldnt need a girdle but would like to at least get the 2 center steel main caps. Where is the best place to get them? Should I worry about the front one too? Is there machining that has to be done for these aftermarket caps? I want the block to be strong, since I dont know what the future will bring as far as performance. Im definately shooting for low 12s high 11s when this block goes in, probably on pump gas/alky inj (we'll see).
I will use the heads that are on the stock block that is in my car now. Already ported, 3angle valve job, 980 comp springs.
SORRY SO LONG; I know its alot of questions, but I know some of you have already been through this or have put some thought into this stuff already. I should be able to get this going pretty soon, since Im putting it together myself and have most of the parts already. The stuff I do need other than maybe the main caps are not expensive and the machine shop work that needs to be done is pretty cheap stuff (mostly just cleaning and checking, cam bearings, freeze plugs, etc).
I am anxious to swap this block into my combo. Im thinking the bigger cam and larger bore will complement the head porting and intake and wake the car up, as opposed to the std cam and bore which I think is kind of mis-matched with all the other performance stuff on top of it. Should be able to get some air moving
ANY SUGGESTIONS OR COMMENTS ARE MUCH APPRECIATED
