Ok. Engine idles like hell, (really rough) but pulls about 18in of vacuum. new IAC, O2, plugs, wires and everything else is working as far as I can tell. At cold startup in the morning, the engine revs up to 2k, then plummets to the point of almost stalling. Then it jumps up and down for a few minutes before it settles. Wish I could figure out whats wrong. The SM shows engine temp fine, so thats not it.
Should my INT/BLM's be showing a number when its not even running? they show 128, which I know to be perfect for both. It also shows those numbers when its running.
Should AF be showing a reading when its not running? Mine does. It shows 03.
I thought there was a way to check TCC lockup with this thing. I guess not. I also found I do have 2 brake switches (old post) I didnt see the other one cause it was too dark.
