finally making progress
tford
Registered Member
First run on new motor this year. 93 octane, 15-17 psi boost on street radials with 0 psi launch got me my first 13 sec pass, 13.8 to be exact. Last year I ran 14.1 with 22 psi on same tires. The major change was 3200-3400 converter swap when the motor was changed. Do you guys think a high 12's are out of the ? with race fuel, slicks, and 22 psi?
try this
Race Gas 110 oct
Slicks or sticky street tires
Chip w/24` timing
22-24lbs of boost
Launch it hard. watch for knock retard and fuel pressure. be sure all is good.
That is a lot of Turbo 6152 you may want to consider bigger squirters like 60# to get the most out of that turbo.
with those mods it should go 11s easily.
