Hunter Dog
- Aug 1, 2015
My 87 GN which I bought in 87 continues to have a gremlin that seems impossible to find. The car is not a modified car, is stock and has 115,000 miles on it. It is a show car and has been garage kept and basically been babied it's entire life. It is only driven to car shows and out for a short drive here and there. I am the one and only owner of this car. It has never been wrecked but will be in an accident if we do not find the issue at hand which is very scary.
Starting about 6 to 8 years ago and out of nowhere the car simply died when driving home from a local car show. This continues to happen on average of maybe two times per calendar year. I put an average of 2,500 miles a year on it over the last ten years. The car has never done this upon acceleration, only when braking or turning.. I have gone over every case and this is the only pattern we can find.
The car has quit in 70 degree and 90 degree weather and when the car has been driven 15 minutes or over an hour on a longer trip. It has quit at a stop light or simply making a normal turn. It has quit under normal breaking or hard braking with no turning involved.
At the first local car show of the year last week it quit on the way home under normal breaking conditions and this was the first time in almost a year it has done it. What took place this time was the service engine soon light and several lights on the left side all came on at the same time before I realized the car was not running. I was in heavy traffic and was lucky no one was in the right lane so I was able to get in the right lane and coast off the road. I have no power brakes or power steering when this happens. Because of the heavy traffic I was not able to look closely at the lights on the left side to see which one(s) were on.
We have been very, very close to being rear ended on a highway several times. Each time when I have been lucky enough to pull off the road, the car has started back up every time after several minutes. Sometimes I have to try several times. It seems the longer I sit there, the more likely it is to start. I have never been completely stranded and I think the longest it has taken to restart is maybe 15 -20 minutes.
I do own a powerlogger and my thinking is I need to have it recording all the time every time I drive it to see if the incident will occur and see if it picks up anything. I also now own a BlueDriver scan tool that I have been using on some other family vehicles with some good results so I am thinking of keeping this with me and plugging that in right away the next time it happens.
Over the last five years I have changed the ignition module/coil pack several times thinking maybe that was it, but over three of them it continues. I have put in a new battery every 3-4 years, an AC Delco each time. This car runs on 93 octane. It has the original motor and wiring harness and ecm. This problem never happened prior to 2016 or 2017.
Please give this some thought and thank you in advance for your opinions. I hope no one else is experiencing this kind of thing but if perhaps someone did in the past 35 years and they found the smoking gun I would appreciate this feedback as to where to look.
