Firing order of coil pack conversion
billygeg
I am going to do the 85 to 87 ign module coil pack conversion. My question is, Does the firing order change to the 87 or does it stay the same. Ordered a engraved coil pack plate with the cylinder numbers on it. Wnat to make sure I get them right on the plate.
Thanks! Bill
Coil-module Wiring
this is from Vortex Turbo Buick Performance...
the Type I Coil & Module normally used on our cars. There are three coils that fire six cylinders. The system is designated a waste spark system as each coil fires two cylinders when triggered. For example when cylinder #1 is being fired for ignition in that cylinder, cylinder #4 is also fired even though it is on the exhaust stroke at the time.
