BlackMetal
- Sep 29, 2005
Yeah I know there's a scan tool forum but replies are pretty slow in there.
Well first and foremost, when I gave it about 3/4 throttle, I got a reading of 7 point something for knock. I know that's not "good" but is it pretty typical of these cars? Or should I be concerned? I run 93 octane, stock except for cold air intake, kirban 3" DP and a test pipe w/ dump tube. Any common fixes for knock?
Anyways, some of the rest:
At5 36
TPS .4 (at stand-still. Calibrated correctly?)
IAC 33
cc 25
AF 05
L8 38
INT 129
BL 145
I bought a used scanmaster without instructions, if someone has the time I would appreciate a run-down of what all the readings are, and what readings you'd like to be getting. I know about Integrator/Block Learn and all that, but I just want to make sure I know what the scanner is trying to tell me.
Appreciate the help.
At5 36
IAC 33
cc 25
AF 05
L8 38
INT 129
BL 145
