first DS run
Mark Brokaw
Ok,first run with DS
Most Kr was 3.5* at 3900rpm looks like its shifting into 4th,both 3rd and 4th are lit up in the sensors
numbers at that time..
tps 3.80
lv8 255
maf 208
iac 73
inj pw 17.50 (56.9%)
coolant 173*
mat 89*
spark adv 21.4*
a/f ratio 12.5:1
o2 volts 749
o2 x count 55
Reading from blm 15 at 122
this is with 18# boost
44lbs fuel press (vac line off)
What do you guys think,Im sure I have left something out,just tell me what to include.Just started trying to figure this out,thanks alot..
if you were wide open your tps is way off
need to get the tps reading close to 4.5 volts at wot
thats first on the menu to get right then get another pass recorded
since the maf is not pegged at 18# looks like your not getting full throttle to start with might have a floor mat stopping your pedal travel or a stretched out throttle cable
hold your throttle down by the pedal and have someone grab the linkage at the t/b and see if it goes any farther ...of course do that with the car not running :D
