Bird of Prey
- Sep 30, 2004
Hi, i'm planning first mods on my TTA.
Some guys don't call it mods, but i do
I have a few questions about them:
160° F Thermostat
K&N 8 Inch Cone Filter or K&N 9 Inch Cone Filter ?
What do you guys suggest. 9" or 8" ? does the 9" cone fit in the space where the original air filter is located?
Intercooler Hose Kit
Adjustable Wastegate Actuator
I suppose, the mounted wastegate in my car is the original one, 15 year old. Boost is going up to 16.5 psi as it should. is there a need to replace the wastegate though?
Walbro 307 Fuel Pump
Do i need to adjust fuel pressure, when i'm going with the stock pump and not raising the boost? or if raising the boost a little, will it work with the walbro only?
Scanmaster II
Am i able to improve my ET at the Quarter without raising boost? i dont want to have to pull race gas, and i dont want to wreck the engine, one day.
And one more question (for now) about changing the timing. how to do this? are there timing-setups to read about, where i don't have to pull race gas, but performance improving is done?
thx alot.
Matt
p.s.: i know, you said i have to do a lot of reading, but pls be so kind to answer my questions. i'm sitting here in austria with no other tta or buick GN owners, 500 mls around. thx
160° F Thermostat
Scanmaster II
thx alot.
Matt
