Thanks To Hartline performance, Southeastern Turbo and a few others I finally got all the bugs work out.
I Never work on a GN Before and was brought this in a million pieces. Need lest to say I had my work cut out for me. The guy had bought a bunch of parts and just wanted the thing put together. It was in a shop in Cal. they had taken apart the whole car over a year ago. I don't know what the situation was but they never put it together.
I've done other work for the guy and he ask if I would work on his GN. I told him that I never worked on one but I am sure I could figure things out. He never told me it was apart. Well Needless to say I thought the thing was running and I would just kinda look over things. He called me when he was on the way back from Cal with the car and ask if he could drop the car off. I said sure. 2 days later ( I'm in Hammond La.) he shows up with this thing on the back of a trailer appart in a million pieces. No brakes, suspension all apar t no engine trans, a 9" loosely put under the car, the body looking pretty bad. At that point I knew I didn't ask enought question before I agreed to work on this.
Anyway, Many hours of research, chasing parts, finding missing parts, getting rid of parts he did not need, Taking apart and redoing stuff and calling guys that had been down this road many times its finally all worked out. I must say its a most impressive ride. The nittos just cannot handle the power. This is a Run down of what was done.
Engine: 3.8 girdle block .020, J&E pistons, Harline 214/214 billet Roller Set up, Champion Race Ported Heads, T&D Shaft Rockers, Ported Intake Manifold, Kenny Bell 70mm Throttle body and plunem, T72 Turbonetics B&B turbo, Turbonetics Racegate, Eastern performance Front mounted intercooler, Atr Headers, ATR down Pipe, Hooker exhaust, Ramchargers Duel fans, Becool radatior, Earls Oil cooler, Earls Trans Cooler.
Fuel: Double pumper, AN-10 feed line, Kenny Bell regulator, 72lb injectors, Fast computer,
Trans: Performance Trans 200r4, Convertor Yank 3800 lock up,
Rear: 9" strange center, 3.55, strange axles
Hotchkis adjustable control arms rear, Giant rear sway bar, Air bags rear, lower spring front, hotchkis front sway bar, Kyb shock at all four corners.
Wheels and tires: Simmons 17" by 9.5 rear and 8.5 front Nitto front and rear drags.
Just finished painting Black. It looks killer
Any one want to guess what this thing should run. Or if you have some thing comparable let me know what it runs and dynoed
Thanks to all
Darren Blanchard
Thanks to all
Darren Blanchard
