The first install I did the reclock thing, but had problems with swaybar clearance (commonly reported).
Last spring I clearanced the airdam piece above the IC scoop opening and now I can install the V4 with the old turbo clocking and no swaybar interference.
That piece of air dam is like an inverted "U" with stiffening ribs every few inches. I just cut out the ribs so that the V4 scoop can smash the "U" and install higher.
Your results may vary.
HTH,
Tom
