flowed injectors
turbo buicks
ESADAH!!!
if i get a set of new 50 LB injectors that havent been flow matched, balanced, tested whatever they do to them, would they still be fine to use in my car? do new injectors HAVE to be flowed in order to be used? what does the flowing process do to the injectors?
I think they just flow the injectors to make sure that they work ok and they all flow about the same. I guess its there way to see if there are any problems with them. If you buy injectors new they should be ready to be put in and ran.
Here is my take on "why I want measured and flowed injectors".
The factory makes them to a + or - tolerance. Don't know what it is myself. Factories (people) do make mistakes.
If you install a unflowed set and start to have trouble that you didn't have before installing injectors. Is it really the injectors or did you pinch or damage some wire or something?
Peace of mind and a close to the same flowing 6 injectors is why I want mine flowed & tested.
Gary:cool:
