FOR SALE: 1987 Buick Turbo-T WE4/WO2 $60,000 Package Deal
WE4TP
1987 Buick Turbo T WE4
Body
Original sheet metal
Repainted, base coat/clear coat
Windshield (2nd windshield)
OER black taillight trim bezels, both Driver and Passenger sides
OER red taillight lenses, both Driver and Passenger sides
OER clear reverse light lenses, both Driver and Passenger sides
OER rear taillight housings with foam gaskets, both Driver and Passenger sides
Bulbs for all rear taillights (Correct Sylvania part #s)
Genuine GM trunk lid bumpers, both sides
New license plate rubber stops, two
Bulb for license plate (Correct Sylvania part #s)
NOS GM trunk weatherstripping
OER black headlight trim bezels, both Driver and Passenger sides
Powder-coated black headlight trim rings
Black headlight bezel and trim ring Torx screw set, all correct/matching
Sylvania headlights (H4656ST / H4651ST)
OER black front side marker lenses, both Driver and Passenger sides
Bulbs for front side marker lenses (Correct Sylvania part #s)
OER front turn signal lenses/housings both driver and Passenger sides
Bulbs for front turn signal lenses (Correct Sylvania part #s)
Reproduction hood/fender rubber bumpers (4, both sides)
Reproduction front air-dam spoilers with all correct studs, washers and bolts
Genuine GM “Buick” grill emblem
Genuine GM grille in perfect condition
Reproduction hood emblems “3.8 SFI Turbo” w/ black edges
Reproduction, red “T” fender emblems
Reproduction trunk lid “Buick” emblem
Reproduction trunk lid “3.8 SFI Turbo” w/ silver edges
Reproduction door jamb vents
Interior
Headliner in perfect condition, not sagging , torn or stained
Reproduction dome light lens with new light bulb (Correct Sylvania part #; base is original)
Carpet (Replacement; not sure what brand; in perfect condition)
Grey 9-piece carpeted truck kit
Original 60 psi GoodYear temporary spare tire and rim w/ grey valve stem cap
Original spare tire mounting parts, 3 pieces: threaded elbow, round washer and plastic nut/handle w/ cardboard filler panel
Original jack and handle w/ two original wing nuts and ‘L’ mounting bracket
Reproduction thin black carpeted trunk mat underneath grey carpet kit
Trunk light bulb (Correct Sylvania part #)
Reproduction dash panel w/ no cracking
Custom, grey embroidered “WE4” Covercraft dash cover
Rear, grey Covercraft package tray cover
ACC grey carpeted floor mats, front and rear w/ front, color logo red “T”
Reconditioned, grey, leather wrapped sport steering wheel
Stock appearance Billet Aluminum horn ring
Auto Meter Sport Comp Guages (Oil / Water on console, Boost / Digital Air @ Fuel Ratio on A-pillar)
Scanmaster 2.1 original style for Turbo Buicks (Red LED version)
GM factory AM/FM cassette radio w/ equalizer, four speakers work well; Professionally rebuilt
GM NOS cigarette lighter (unplugged; trips fuse)
New J-rod spring w/ proper shift handle adjustments performed for proper function
NOS grey shifter handle w/ Billet side inserts, bottom insert is factory chrome plastic, new retainer staple
New shifter indicator light bulb (Correct Sylvania part #)
New under dash convenance and glove box light bulbs (Correct Sylvania part #)
Under dash black metal support brace for drivers side plastic panel
Window Racer module for faster operation of power windows
Engine
42 lb. injectors
Turbo Tweak chip
Precision TA60 turbo
Adjustable fuel regulator
Walbro 340 fuel pump
Casper’s Hot wire kit
Down pipe A-arm black, powder-coated bushing shield
Arizona GN big aluminum radiator with duel electric fans and Caspers wiring harness kit
Remote engine oil cooler
Remote transmission oil cooler
Custom stainless turbo cover (SpoolFool)
Duttneck Garrett intercooler
Heavy-duty hoses for charge pipe
3’ downpipe
Limited edition carbon fiber (Rare) Drip Lip cover (SpoolFool)
Cool air intake setup w/ K&N filter (Custom Fabricated and installed by Turbo Lou/Lou Czarnota)
A/C Compressor and high-efficiency condenser w/ conversion and recharge (blows cold / all fan positions working)
Engine rebuilt:
TRW .030 forged pistons
208 hydraulic cam
Ported heads
Big valves-stainless-1.71
New exhaust manifolds
ARP head bolts
Heavy duty solid motor mounts
GM NOS power steering fluid reservoir w/ new reproduction stock hoses/stainless hose clamps
Billet aluminum “Buick” EGR block-off plate
LT1 MAF Sensor (Cardone)
MAF Translator w/ Billet aluminum logo cover “Buick Motorsports”
Drivers side relay cover
Hood light bulb (Correct Sylvania part #)
GM NOS 8-hole hood insulator with Buick Turbo Six logo, new push-in fasteners
Rear Differential
Moser rear axles w/ new bearings
Differential girdle
Exhaust
Pypes 2.5” exhaust system with RacePro mufflers (no catalytic converter)
Suspension
Bilstein B6 shocks, front and rear
Lower, correct front shock mount bolts and clips
Stock springs front and rear both w/ new insulators
UMI front sway bar w/ red polyurethane bushings
UMI drive shaft loop
ATR large rear sway bar
UMI rear, upper tubular control arms w/ black polyurethane bushings
UMI rear, boxed lower control arms w/ black polyurethane bushings
UMI rear shock tower brace
Transmission
Heavy duty U-joints
Rebuilt 200R4 transmission handled by Turbo Lou/Lou Czarnota (Transmission came from low-mileage Grand National never perviously rebuilt)
New torque converter handled by Turbo Lou/Lou Czarnota
Brakes
Reproduction front brake dust shields
AC Delco Professional ceramic coated rotors w/ new races
AC Delco ceramic coated calipers w/ new caliper pins
AC Delco Professional brake pads
AC Delco wheel bearings, grease seals and grease caps
AC Delco Professional front brake lines
AC Delco Durastop rear steel brake drums (Have aluminum drums that will come with car)
AC Delco Durastop rear brake shoes
AC Delco rear drum brake spring kits
Wheels & Tires
OER GNX style 16” wheels (4.5” back spacing / 0 offset)
BFGoodrich Sport Comp T/A 245/50 R16 tires
Bracing
Front end frame braces (complete triangle, both kits)
Upper radiator/fender support braces
Rear seat frame brace kit
NOTE: I have many additional spare parts both new and used that I may consider negotiating with the sale of the car. Would actually prefer selling everything as a package. I have priced this as a package deal at $60,000. Buyer would get everything. I'll keep adding photos as I can take them this weekend.
The OP hasn't been on the site since the day after he posted the ad.....
May not get a response.
"Got Damn, ran three blocks and only farted..."
Some of you old guys will get that....
