For sale -- 42# injectors & chip, 60# injectors with two chips.
Located in LI, NY
New addition to the "For Sale" list
A- Reds ALKY chip for 60# injectors. $75.00 shipped to continental US
B- Pit Bull chip - HP 137R-528SDL Copyright 1992- $25.00 shipped to continental US
1- 42# Injectors with matching TT 93/Alky chip --still on the car. $160.00 shipped to continental US
2- 42.5# Injectors with matching TT 5.7 93/Alky chip $160.00 shipped to continental US
3- 60# Injectors with Matching TT 5.7 93/Alky chip -- Still on the car. $200.00 Shipped to continental US Sold
4- E85 TT5.7 chip for 60# Injectors $75.00 Shipped to continental US
5- 84-85 Block with oil pan. Needs to go 30 over. Make offer.
Edit
what was your set up for the e85 chip .turbo ? stall?
Stock heads with bigger valves and bowl work. 206 Billet roller cam, 62 MM throttle body, Scanmaster, K&N, Boost Gauge, Adjustable FP reg, Reds Double pumps, -8 feed line, TT E85, ALKY Injection, Dutt neck OE IC, TE-60, RJC boost controller, RJC Power Plate, 3" THDP, 200-4R built, 9.5 LU 3000 stall, 2.5 Dual Exhaust, Volt booster, Wide Band, Power Logger, 3.42 gears.
The most that i could safely get out it is 20psi.
so will it work with a stock set up the only upgrade i have is te44 and 2800 stall no alky .
You need a LOT of fuel volume with E85.
If your fuel system Is stock you can forget about e85
Ive been told that 60s on e85 are only good to 420 hp .
On my set up the most that I can get out of the 60s is 20psi of boost before it leans out.
i do have new dp setup to put in when i get all the parts to do the e85 .all i need is the chip .
