alwayscode390
- Apr 2, 2009
I dont hear much about Forged Cranks or H-Beam Rods with the TTA's.
I saw that many people have ran 10's on the stock stuff ... but a solid tune is a MUST. I figure it couldnt hurt to upgrade just for the added strength right?
Since the GN and TTA's share the same crank cast numbers ... does that mean we can swap cranks and rods with no problems?
I just want to go forged crank like this (3.400 stock stroke right?):
BUICK GRAND NATIONAL GN TTA 4340 STEEL CRANK CRANKSHAFT - eBay (item 200512824317 end time Jan-23-11 14:48:41 PST)
Forged H-Beam Scats like this:
TTA GRAND NATIONAL GNX SCAT STEEL 900HP CONNECTING RODS - eBay (item 200326368756 end time Jan-19-11 17:18:57 PST)
Are those the right specs?:
5.970" Rod Length Apprx. Gram Weight N/A
2.249" Crank Pin .940" Piston pin
B.E Width .850" Bushed Fit Pins - Floating
I was going to buy a crank and rods ... then send them to be nitrided, but chances are that will get pricey too.
Thats just what I found on Ebay real quick ... if you have other brands to recommend let me know. THANKS ---
