Hey Guys, been a while since I posted in tech, but having an issue. I rarely drive the GN and in the past 4 or 5 years have put maybe 1000 miles on it. I do keep stabil in the fuel, but had to rebuild a carb in my ATV recently that was also stored with stabil in the tank, so I'm not a huge believer in the stuff.
The GN keeps fouling the #6 plug, I can't tell if its oil or gas, I think its gas. I have swapped plugs with new, NGK UR5's gapped at 31, swapped ignition modules, coil packs, tried #6 plug wire on #2 and the #2 wire on #6, even done a compression test. Vacuum doesn't fluctuate at idle, so I am hoping its not a flattened cam (also use that ZDDP every oil change); so, before I go through the hassle of swapping injector #6 with #2 to see if now #2 fouls the plug, is there any other things to do before? Injectors don't have very many miles on them, they are the 60/65#'s that came out a few years back. Fuel pressure doesn't seem to drop very fast either.
