Rickerbucks
- Feb 18, 2003
I have a 383 b2b blower LT1.
This is a new motor. I was running around the last few days and I had two WIERD problems. The first time I was running well and then suddenly, BAM, it is running pig rich. So rich it stalls the car at idle. Now at the time I had fan problems and I put it down to be overheated. The car cooled off and I was able to get home. I fixed the fan and no problem.
Three days later and I'm slowly improving the tune and BAM, its running stupid LEAN. Its bucking and stumbeling and I have to increase the VE map by about 15 points accross the board to get it to run well enough to get home. i pulled the plugs and they indicate running rich.
I should also point out that I have been burning a disturbing amount of oil and I'm hoping that the rings will eventually seat better. Would the oil have fouled plugs or the O2 sensor?
I have a log and the (good) tune available - the one that causes the lean condition. I cannot SEE any arching plug wires and I replaced the four easiest plugs. (its a sob to change plugs on my motor especially with headers). I also changed the oil.
Any hints guys? the only tables I MIGHT have fooled with before this happened was the throttle follower map and the map that is suppose to help with tip-in.
Another question. Originally i had a lot of popping on deceleration and the afr read lean. I fattened the BOTTOM of the VE tables to get to the 13.0 afr I want BUT I'm not sure that was the correct way to do it. Anyone able to advise?
One more Q? I also pulled the O2 sensor to clean it. I used WD40. A friend just told me that oyu will ruin a STOCK o2 with WD40. Please tell me I'll be alright?
