Okay, everyone knows my current situation with code 31, the wastegate solenoid thingamabob. Fricken yellow orange SES light is irritating. How do I check to see that its functioning correctly or not? I really dont know how to check this. Also...what would happen if I disconnected the plug to the wastegate solenoid? probably a bad thing. Some one on the hot-air section said that the egr solenoid could be sharing the same ground as the wastegate solenoid. but since I dont show a code 32 anymore regarding my egr, the ground could be in tact? not sure
And if the wastegate solenoid is still good...what else could be giving this code? could the wastegate actuator setting the wastegate solenoid off? or worste case...my ECU is being faulty.
? I did a search on code 31, one guy source his problem with a pinched tranny line
Man this sucks ass!!!!!
