front filler fastners
rmc123
I removed my front fillers and cut the plastic fastners( one each side) that attatch them to the header panel. Are these fastners available at a parts store? Thanks ....
You should have no problem finding them. They are Christmas tree clips. Look in the help section.
Be careful
It's very easy to break the header panel in this area.. I use a small "j" nut and a 7mm head screw. This will give a little adjustment on the filler where it meets the grille. The plastic clips will sometimes become loose,letting the filler "droop' or hang in this area..
