Little6pack
- Jun 2, 2002
1) MY front flex line is leaking near the caliper screw in area & needs replacement. I assume I would not need to take the caliper off just to install a new flex hose?
2) I also notice the FRAME mount is busted where the flex hose meets the brake line at frame.
Would you guys know if they make a fix kit or replacement for the frame mount point tab.
Seems like someone before me used a plastic pull tie to hold it.
I was thinking of making a bracket with a small C clamp.
