I'm waiting on another set of LCA's from a fellow board member. Once I get them cleaned prepped and painted I'll be ready to tackle this again.
So no I haven't bothered to have another go. This issue is common on many cars of any age, if you do a search on the internet you get crazy hits like I did.
Here is a run down on the methods I've found which the person(s) stated were successful.
1) Cut the head off the bolt and flush on the other side of the mount. Bend the ears on the frame mounts out enough to allow the LCA to drop.
2) Cut the bolt right between the mount and the LCA on both sides then drop the LCA.
3) Heating up the bushing directly to melt the rubber off, then again apply heat to the sleeve. This should break the rust and allow the bolt to be extracted.
4) Using combinations of heat, penetrating oil, BFH, or a air chisel/hammer to get the bolt out with everything intact.
I'm going to go the route of number (2) and just cut the damn thing out. The bolts/nuts are replaceable (rear bolt only from GM) or both from Spohn Performance or GBodyparts to name a few. Any shop that does brakes, exhaust, suspension or any other underbody work does the same thing where permissible. Otherwise you spend more time fighting w/the seized fastener than the whole job takes.
Which method you go with, should you need to, will largely depend on your resources at hand. My Regal isn't a daily driver and I have another car to make runs if need be for tools and such. However up here the local parts stores have long since stopped stocking the right hardware for these cars and most parts.
So I didn't want to press my luck and snap something without having spare parts available.
Lube up the nuts a day or so before and use a 1/2" impact gun to take the nuts and bolts out. If they move your okay.
