JRNYMNDAVID
MACSTURBOTA
- Jun 25, 2006
Has anyone installed a front mount intercooler on a TTA?
Manufacturer? Links?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Problem with front mount for TTA is it will not see to much air to cool it down. Unless you want to cut a whole in your nose cone.![]()
NOW"THAT'S WHAT I'M TALKIN ABOUT!!!!"Im dunno bout that. Dequick did make them, they were very similar to the buick ones but a different lower mount and different tubes coming off the tanks.
As for getting air to them, I'll bet the air dam that mounted to the bottom of the intercooler gets more air to it than through a stock location scoop, and no heat from the radiator. You can see the air dam in this pic under the nose, it looks a little scuffed up but I've repainted it scince.
Steve
Steve
I took mine off.. hits everything.
CAS (charged air systems) made them for awhile too. (looks simiar to the above photos.
I am looking for one just like the above or a actual CAS front mount.
where did you ever find that ???:biggrin:
Razor:I took mine off.. hits everything.
It is a CAS unit
I make all my piping out of mild steel mandrels and streights. They don't collect as much heat from the engine bay and the price is right. I also paint them to match the engine bay.
Thanks, Scott!
