front parking lamps intermittent
tta1240
CAMEL TOE
i noticed on my car that my front park lamps dont come on at times.i checked the bulbs they are fine,all other lights work.
Just at some times?
Or all times?
I can scan the schematic and psot the pdf if you want to look at the diagram and try to figure out the various culpirts.
I'd have to look, but I do think each side is fed from seprate wiring harnesses; i.e. passenger side and driver side.
I think that because I cleaned all those wires, tie wrapepd, and loomed them proper like, instead of the wild wiring the factory left.
But can't say for sure without looking and reading the schematic.
If your head lights are working all the time but your having a problem with just the parking lights. I would check your switch on your dash and check the connectors behind them.
