Front Pump Gaskets
5280GN
I am going to install a new front pump when I put a new torque converter in next week. I got the TCI front pump assembly and it did not come with gaskets. What other gaskets do I need besides the front pump gasket and o-ring? Are there any other gaskets I should get for when I drop the trans? Thanks.
Has the drain back been drilled out on your new pump? Are you swapping the boost valves and pressure regulator stuff or is the new one equipped with equivalent pieces? Do you have the ability to measure the end play and swap to the correct thrust washer? You can adjust to bigger play with additional gaskets. But if you need less you will need a different washer. Just what I came up with.
Did it come with a stator support already installed? Loctite the bolts?
The drainback has been drilled out. The boost valves and pressure regulator valve are the specs i need. I'll look into getting some thrust washers to adjust the end play.
