Apr 23, 2024 #1 P plcguru Member Joined Aug 21, 2008 Messages 50 When you install the washers on the front oil pump bolts do you use sealant on the screw threads or just the install washers themselves to prevent tranny oil leaks? Which sealant is best to use if I supposed to use it? thanks
Apr 23, 2024 #2 G gnmaster2004 Active Member Joined Mar 4, 2004 Messages 993 Just use new washers, no sealer
