Which side of this front seal is supposed to be facing the block? The timing cover I have is an aftermarket Silverseal HV cover. The seal is installed from the outside. If I put the seal in the way I think it supposed to go the tensioner spring will be on the outside facing the balancer. I don't want to end up with a leak because I drove the seal in from the wrong direction though. The seal part number is B231-710613.
Thanks,
Thanks,
