I'm debating right now whether to do or not to do a Frame off this winter, or just a repaint. The car was re-done 7 years ago, before I starting doing autobody work, it was done good, but not great, paint peeling inside jams/under bumper fillers, dry spray on lower parts of car, I've wet sanded the $hit out of this thing to get it to look how it does.. just general things I'm sick of looking at. I just hate having a car that I know could be better. everyone asks if I painted it, no I didnt, if I did it would look better.
So...everything has been replaced/improved except for the front control arms, coil springs, brake lines, and fuel lines. It's a street driven car, w/ the occasional visit to the track. (body bushings, rear end/control arms, sway bars, frame braces, driveshaft, crossmember, idler arm, tie rod ends, ball joints, gas tank and straps, and everything else have been changed to new or performance parts)
The original control arms have the original bushings in them, the arms are were rusty, I cleaned them up a few years back, I want tubular arms/new bushings.
Stock spec alignment is fine, I'm just looking for some controls arms I can just bolt up and not worry about pressing bushings in...and not pay an arm and a leg for. Most importantly be a quality piece.
