Like the title says, I have this engine that I HAVE TO GET RID OF!!!! It has a ta33 with te61 center section with 60 miles on it. Its got 36lb blue tops, 92 thrasher chip, ported intake, ported turbo to intake adapter, new injector harness, IAT sensor with harness, 86-87 ign module and coil, ign module adapter plate, new oil feed line for turbo, and ign module adapter harness.
This engine does run, but is a little low on power for some reason. I THINK it might be bad rings. It does drive, but with a tiny sputter. Like I said it is either those rings, or something stupid like a bad sensor somewhere. It runs, so I know there is nothing that would destroy the engine. The turbo does spool up, but the highest Ive gotten it is 10psi, and I think again thats because of the problems such as possible rings. This does have to go.
I would like to get 1400 for the entire thing. Wiring, EVERYTHING, except afpr. =-) Ill put the stock one back on. I want the adjustable one. I am negotiable. Please, no dreamers. Ive already dealt with one so far.
