FS: 87 Engine, Maryland
GerrywithaG
The engine is currently running STRONG in an 87 GN located in Bel Air, Maryland. You can drive the car so that you know what you're buying, and if you show up at his place with money in hand he will pull it out (the engine;)) himself in front of you! After that, in a few months it will be up here in Massachusetts at Cottons being pulled out and replaced with a built motor.
Stock 109 block
212 / 212 Comp Cam Roller w/ chain, lifters
Champion Ported Iron Heads
T & D Rockers
GN1 Valve Covers
Champion Ported Stock Intake
60lb injectors w/ chip
Hemco 65mm Plenum (will include throttle body if needed)
TA Harmonic Balancer
TA High Volume Timing Cover
Oil pan
All the engine mounted sensors
Underdrive pulleys
NO accessories / brackets / harness / turbo / intercooler / downpipe / etc
The block has approximately 100k. The aftermarket parts have approximately 1,000 miles of use.
Asking $4,500.
PM or Email me for contact information (he doesn't use computers) :cool:
harleyjack@aol.com
Price on the TB (if separating) since it was not mentioned above w/plenum.
CORRECTION:
The 212 Roller Cam is not included, and the TA Balancer and Timing Cover are STOCK!!! NOT TA, so they are not included.
Yeah not quite getting this.... So what is it exatly you are asking $4500 for?
