{FS} TTA #5 Festival Car Cloth Seats Project ---
alwayscode390
Bigger pics (same as above) here:
http://www.cardomain.com/ride/3312652/1989-pontiac-trans-am#33126520003
This is a 1989 Pontiac Turbo Trans Am TTA.
They only made 1555 of these cars, and only for one year.
It is the 20th anniversary Special Edition.
These cars came from the factory with the Turbo Buick 3.8 v6 and an a/a intercooler. The same setup as the Grand Nationals.
I ran across this car locally and jumped on it because of its history. Its car #5 , its a documented festival car (it was at the Indy 500), and it has FACTORY cloth seats (1 of 187).
It has 155,000 miles. At one point it was obviously a great running car.
I have only put 200 miles on it in the last 3 years, other than that it has sat in storage waiting for a bunch of mods.
I had "big plans" for it (heads, cam, turbo, ect) and was going to molest it all to hell ... and decided that I probably should sell it off to a collector or someone that wants to mainly restore it.
Interior is fully stock including the radio and steering wheel. NO tears or RIPS in the interior anywhere.
T-Tops do NOT leak, but the black bars are starting to rust.
The paint is in great shape, BESIDES the clear coat is starting to peel off down the side of the rear pillar pretty good. Will need a repaint ... not many chips in the nose.
No major dents, or dings that I notice.
Headlights, power antennae, and power windows work great.
Car has ALL badges. Original Pace Car on the sides. Has original t-top bag in the back with the TTA logo.
Needs the hatch motor replaced, but will include it.
The rear spoiler is splitting pretty good but is complete.
Needs a cat converter if its to be inspected in the city, I have one and can include it IF I CAN FIND IT ... I recently moved. (a universal magnaflow).
The car runs GREAT when it runs. Heres the catch , it wont start all the time. It either needs a new starter, something in the column ignition, or the VATS disabled. All are easy fixes, and I can include a starter IF I CAN FIND IT ... I moved recently.
MODS:
*Razor Meth Kit (always shows its LOW , will need a new sensor)
*KN Cone Filter
*Nitto Drag Radials
*Dyno tune,
*Flowmaster 3" Exhaust with cat delete from DP back (STILL HAS STOCK TIPS)
*Edelbrock Performer RPM cam/lifter/springs/timing chain set (20k miles on it),
*MSD 50 lb injectors (20k miles)
*Scan master,
*Autometer Boost/Pyro/Fuel pressure guages on the a-pillar
*Manual fan switch override,
*Fuel pressure regulator (adjustable)
*msd Coil Pack and ignition module
*MAF translator with LT1 maf
*adjustable wastegate actuator
*rebuilt stock turbo (20k miles)
*Custom Mease Aluminum intercooler shroud
*high torque starter (20k miles, car eats up starters from the heat)
Maintenance Parts replaced with less than 500 miles on them:
*Crank Sensor
*MSD plug wires
*AC Delco Plugs
*Misc Vaccum lines, fittings, and breathers
*Valve cover gaskets
*TPS sensor
It honestly should be an easy project for someone who just wants a cruiser. I let it sit because I had "big plans" for it (heads/cam/turbo, ect).
I am sick of watching it age and never finding the time to put into it.
I'm not trying to make any money on this, just trying to recoop most of the money I have into it.
Here is a video of it idling before I parked it up until this point:
http://www.streetfire.net/video/TTA-Cam-Idle-Vid_680517.htm
NADA is valuing these cars at $13,000 - $22,000. Not sure if this cars history will outweigh the high miles or not.
***AS IS I want $9999 OBO
You are welcome to come look at it if truely interested and try to get it running or do whatever tests on it and check it out. No tire kickers please ... i'm a busy person with limited spare time.
THANKS for your time !!! :) ---
you should obviously have pics of your interior posted since that is what more or less makes your tta unique from the rest. might also help to post up where your located because a lot of times people want to inspect cars personally especially at the price your asking. i wish 1 of my tta's was a festival car.
probably also gonna be asked if you have the owners kit. good luck with the sale :)
No Owners Kit.
The car is in Saint Louis, Missouri.
Nobody serious has asked me for any more pictures ... due to my work schedule its hard for me to get to the car while its in storage. Once someone shows some honest interest I will go wash/detail the car and take some pics.
Right now this is just sorta a feeler thread ... I really hate getting rid of this car ;) . I'm not in a hurry ... it will happen sooner or later.
I am sure there is a specific buyer out there for THIS car , we just have to find each other HAHAHA!!!
Thanks for the advice :) ---
Here is the new updated C.List Ad ---
This is a 1989 Pontiac Turbo Trans Am TTA Pace Car Special Edition ws6.
*** THIS CAR IS CURRENTLY A PROJECT CAR ... MEANING IT NEEDS WORK, AND CANNOT BE DRIVEN HOME ***
They only made 1555 of these cars, and only for one year. (5 ACTUAL Pacecars, 1550 to the public)
These cars are FAST stock. Specs are top speed of 170, 0-60 in 4.8, and the 1/4 mile in 13.4!!! Fastest Production Trans Am STILL TO DATE!!!
These cars came from the factory with the Turbo Buick 3.8 v6 and an a/a intercooler. The same setup as the Buick Grand National but with a cross drilled crank, better heads, stock headers, and the GNX style intercooler (more fins per square inch).
I ran across this car locally and jumped on it because of its history. Its car #5 of the 1550 produced, its a documented festival car (it was at the Indy 500 ... only 150 cars were there), and it has FACTORY cloth seats (1 of 187 built like that).
It has 151,XXX miles. At one point it was obviously a great running car.
I have only put 90 miles on it in the last 3 years, other than that it has sat in storage under a car cover waiting for a bunch of mods.
Interior is fully stock including the radio and steering wheel. NO tears or RIPS in the interior anywhere but a 3" tear in the headliner in the center near the back, and a few scratches in the fabric behind the driver on the left side. You can get replacement GTA stuff for cheap. VERY MINOR wear in the seats and carpet with no major stains. Steering wheel is pretty worn, and the ship knob is splitting at the leather seam.
T-Tops do NOT leak, but the black bars are starting to rust around the hatch.
The paint is in good shape, BESIDES the clear coat is starting to peel off down the side of the rear passenger side pillar pretty good and in other places randomly. Will need a repaint in the area to fix that... not many chips in the nose. The paint in the 80's and 90's was very thin, and has worn down to the primer on two places on the TOP of the hatch, and on the top front (between t-tops and windshield).
No major dents, or dings.
A/C Blows , but I havent seen if it blows cool or not ... probably will need a recharge.
Car has ALL badges. Original Pace Car logo still on the sides. Has original t-top bag in the back hatch with the TTA logo.
Needs the hatch motor replaced, but will include a new one. The rear of the inner hatch has been taken apart , and is ready for the new motor to be installed.
The rear spoiler is splitting pretty good at the seams (very common with these fiberglass peices) but is complete.
Needs a catalytic converter if its to be inspected in the city. You can buy a new Magnaflow universal 3"in/out one for $60 on ebay.
The car runs GREAT when it runs. Heres the catch , it wont start all the time. It either needs a new starter, something in the column ignition, or the VATS disabled. All are cheap, easy fixes whether you do it yourself or take it to a shop.
MODS:
*KN Cone Filter
*Nitto Drag Radials in the rear ... good Kumho Ecsta front tires.
*Dyno tune,
*Flowmaster 3" Exhaust with cat delete from DP back (STILL HAS RARE COLLECTABLE STOCK STAINLESS TIPS)
*Edelbrock Performer RPM cam (204/214 duration-0.448/0.472 lift)/lifter/springs/timing chain set (20k miles on it),
*Scan master Gauge,
*Autometer PHANTOM Boost and Pyrometer guages on the a-pillar in a triple pod with a WIDEBAND gauge.
*Fuel Pressure Permanent Gauge on the Fuel Rail under the hood.
*high torque starter (20k miles, car eats up starters from the heat of the turbo downpipe, this is common)
*good condition rotors and brake pads
*Crank Sensor
*MSD plug wires
*AC Delco Plugs
*TPS sensor
*both front end tie rods (less than 50 miles on them)
It honestly should be an easy project for someone who just wants a cruiser or something to take to the car shows.
I let it sit because I had "big plans" for it (heads/cam/turbo, ect) and no longer have the time or money to complete the project.
I HAVE A VIDEO OF IT RUNNING , JUST EMAIL ME AND I WILL SEND IT TO YOU IF YOU ARE INTERESTED. CAR HAS A NICE LOPEY SOUND!!!
This car is appreciating in value everyday ... and is SURE to be a collectable. It is one of a kind and cannot be duplicated or replaced!!!
It is the LOWEST number car in the Turbo Trans Am registry owned by private owner that is not an ACTUAL pacecar!!!
This will probably be your ONLY chance to score one of these cars locally ... without the hassle of buying a sight unseen car off the internet and dealing with shipping!!!
YOU WILL NEED TO SET UP YOUR OWN TOW TRUCK ... and I can bring a battery if you want to check the electronics, but the car will NOT come with a battery.
***AS IS I want $8500 OBO
I will be adding video links to the engine, interior, and a walk around of the car once I can get them uploaded to youtube. Email me if you want them that way.
BACK FOR SALE , lol . I can get it running if you want , but the price will go up over $10k ... just wanted to give someone a chance to put $200 in it, and work on the car themselves to save $2k ---
