Any of you running alky setups with a 4-5 gal fuel cell mounted in the trunk?
I have a 3/4 gal container gravity feeding a Shurflo 8000 series pump under the hood right now (pump is mounted directly under the container).
I am looking to buy a 4-5 gal black plastic fuel cell from Summit racing and put it in the trunk with the Shurflo mounted below it so it will be gravity fed there as well.
What size line do you guys run from the pump to the front of the car? Most fuel cell have -6AN out, so I will just run a -6AN line from the fuel cell to the pump. But from the pump to the engine bay what line size should be used? I use a -3AN now since its under the hood and such a short distance, but I'm sure a larger line must be used due to the increased distance from the trunk.
Are there any special fuel cells you are using? Or just a generic one?
Any experiences or info would be appriciated.
Also if you have pics that would be great!
Thanks.
Thanks.
