Anyone got any idea what could be wrong? Here's the rundown.
My ol girl's been down for a while (probably 8 years) and I'm in the position to get her back on the street. When it went down I was having wiring problems that I think I narrowed down to a bad 'Dial a chip' that fried my computer. So in the last few months I've put in a new computer and Cotton's #6 performance chip. No dice. Wasn't getting fuel to the rail. So I dropped the tank and put in a new Walbro stock style and a new Hot Wire kit. When I turned the key, the pump came on for a few seconds and then nothing. I assumed the lines were clogged but today I dropped the tank again and pulled the rubber lines off of the steel line coming from the tank and still can't get the pump to run. Is there anything that would be keeping it from running? The old pump worked when I put fire to it on the bench so I'm pretty sure the new one's not faulty since it's doing the same thing the old one did. To add to the confusion, I've got a switch that will turn the pump on to dump the tank and it won't work. It's tied into the fuse box, not running direct to the pump.
Any ideas?
Any ideas?
