If the components are not mounted, it's easiest to send it to someone who has a test bench with all the equipment.
If they are mounted on the car, you apply the rail pressure you will be running (add regulated shop air to the reg or just turn the base fp up), loosen the return and arrange it so fuel dumps into a calibrated bucket (gallon paint can for ex) and time how long it takes to fill the volume. Divide by time and convert to whatever flow rate you need.
