Steve87GN
Oh come on...its just a 6
- Dec 3, 2005
Hey everyone. So, here's what I'm trying to tackle now, and I'm not sure if the two are related or not. First, I've had a knocking under high-throttle, high-boost for a while now that I can't get rid of. I just put in new injectors on Sat. and its still there. However, I noticed that when I went to do the new injectors, there was no fuel pressure in the rail whatsoever. The car had been sitting for about 12 hrs., give or take. Now, the car is a little harder to start (probably because I'm not using my factory-original injectors that were leaking).
So, on Tues., I hooked up a fuel pressure gauge to the rail. She was holding at 36 PSI. That's a little low, isn't it? I did the WOT test (pulled the vacuum line off), and the pressure dropped to 32 (at least, that's the WOT test on my 93 Z28). Again, isn't that low? So, I shut the car off with the gauge still attached and let it sit. 30 min. later, the pressure had jumped up to 43 PSI. However, it still took a little effort to kick over. So, I shut it off again and came back an hour later, only to find the pressure had dropped down to around 17 PSI-ish.
For the fuel system itself, here's what I'm running (to the best of my knowledge):
New Tomco 30 lb. injectors from Kirban
Bosch 237 fuel pressure regulator (TTA FPR?)
Supposedly, a Walbro fuel pump (not sure how much I believe that)
For ignition (in regards to the knock, if it is not fuel-related):
Stock coil
Taylor 8mm plug wires
NGK Iridium UR4IX plugs (part #7401)
Any ideas? As always, thanks for all your help everyone.
Stock coil
