fuel lines to injector rail
ronbuick
Does anyone know who has the fuel lines in stock that go to the fuel rail, the General says that they are discontinued, part numbers, 25526145, 25526146, thank, Ron
Fuel lines?/
Ron, I think S.E. turbo had some made up. Give Dana or Paul a call at: 770-529-3695.
HTH,
:cool: :cool:
Chuck,
Have you ever made up a set of the intake mounted fuel lines from stainless braided lines with A/N fittings for a TR? (Aeroquip/Earl's)
What would something like that cost?
________________________________________________
(And, as always, a special thanks for all the tech advice you
provide & share, both on the board, & in person.)
Stainless lines
I've made both feed and return w/ braided.
I had a one off adapter that I found for the TPI lines on a SBC that I used for the feed to hook to the line down at the frame.
I took an old return tube and cut it and silver soldered a -6AN on it.
I used the Saginaw adapter at the FPR. I used a -6 to inverted flare on the feed at the rail.
This setup got fairly expensive, as I recall. -6 hose at $6.00 ft, 4 hose ends at $6.00 to $20 ea and I can't remember the adapters cost.
Would shoot about $75 to $100, I'd think..
Don't know what the repop OEM style costs...
