Fuel press reg
Sal Lubrano
Is there an o-ring on the metal line that comes in to the bottom of the fuel pressure regulator? Can not remember.
Sal
YES. There should be an 0'ring on the metal line that screws into the regulator.
There is an O-ring on the bottom where the fuel line screws in and an O-ring where is attaches to the fuel rail. You can get both O-rings at Autozone or Pep Boys.
Turboman, would you have part#'s? The guys at my Autozone couldn't look anything up. They had some generic fuel inj o-ring kits, of which only 1 matched any of the GN's fuel rail/fuel lines/reg. Thanks, Brian
Unless my memory is faulty....The rubber 'O' ring sealing the fuel rail at the FPR is the same as the 'O' rings on the injectors....I've never replaced the one at the bottom of the FPR. Lube it with motor oil for installation.
HTH
lee
Sorry, I don't have part numbers but I got mine at pep boys and they had it in stock. I may have the little bag at home they came in with a part number on it but I am at work until 2:30pm today. I can look when I get home.
