Tim Barnum
- Oct 15, 2001
Just for starters. What should the fuel pressure be with no vaccum if the boost level is at 20psi? I have the stock turbo, 40lb injectors, ported heads, 218/218 cam, 3" dp, big neck innercooler, 340 fuel pump and 45deg KNOCK even with no boost. The 3" down pipe is hitting the headers causing false knock. So it's hard to tune with the false knock. I would like to get an idea where it should be set at to be safe with 101 unleaded fuel until I can get the DP problem fixed.
