czimpel
Boost...gotta get some!
- Aug 16, 2012
Just replaced my DW300 pump because my fuel pressure jumped all over the place under boost. With the new pump, I have the same issue. It will rise 1:1 until about 15# of boost, then will drop to 40PSI then jumps around 10-15 PSI.
Could this be a bad FPR? I have a 2 year old Accufab on it.
Possible a boost leak on a vac line somewhere?
I've checked the tank pump to hanger hose again, and it is all fine.
I also am able to put a mighty vac on the FPR and pump it to 30psi and the fuel pressure rises 1:1 and hold accordingly.
