Fuel pressure not holding after shutoff
  • Thread starter Thread starter GTEATER
  • Start date Start date
G
GTEATER
Guest
Fuel pressure is dropping to 0 instantly when engine is shutoff.
There is not fuel leaking anywhere....whats would cause this and is it important.
The car has been slowly leaking pressure down after installing 83#er, but not instantly like now. It previously would hold some pressure for a couple of hours, loosing about 15# per hour.
Hey Kevin,
Try a different regulator. I cannot see it being pump related as the relief valve tends to weaken over time and not over night. I can get a stocker (233) if you wanna try.. Let me know
Mike Banas
87GN
did you loan your regulator to Mike?
His car was doing that with a couple of regulators until he put a new one on. I'm thinking one of them might be yours he was trying? You're welcome to use mine if you want.
try running a gallon or 2 of xylene in the gas to clean the injectors. Mine will do this every year or so (actually it drops faster then usual but not instantly) and I run some xylene thru and it cleans the injectors. This helps me..
If it is the pump check valve or the regulator...is it a performance issue? all seems well when engine is running.
When I had this problem it was a leaky injector.
I believe that www.gnttype.org has a diagnostic procedure that can narrow down the source. Check in their tech section, I think under fuel.
good luck,
Scott
