SignUp Now!I'm assuming you mean when you shut the car off...The fuel pressure at the rail drops quickly....
You only need 1 injector to leak down a little bit to lose the pressure on the rail...Either that or the check valve in the pump is not holding.
This should not affect the car at all while driving.
If you have another set of Injectors...swap them out just to see if the pressure holds,If It doesn't,It is more than likely the check valve....In which case I wouldn't bother with it until it's time to do another fuel pump.
If It does...start swapping the Injectors you took out back in one by one until you find the culprit.
Same issues I had and I will be replacing my fuel pump with a Walbro 340 ... funny thing is I installed a Walbro 307 (or is it 305?) about 3-4 years ago so did not last to loong and now I have to drop the fuel tank again
