Jan Larsson
- Nov 22, 2001
So got all new injectors, brand new fuel regulator, clean install with new injector wire harness and a brand new fuel pressure gauge.
Problem before was it looked like a leaking injector and fuel pressure died as soon as I turned he ignition off. I was told fuel pressure should hold 1 - 2 mins after I turned the ignition off.
Right now the car runs but looking at the fuel pressure (I have 42 psi vac off while idle), when I turn the key off it's holding the pressure as long as the pump is running (for a number of secunds after the ignition is turned off) when the pump is turned off the fuel pressure starts to go down (slowly) so within another 10sec or so I have no fuel pressure. This is better than I had before swapping out my old injectors but it's not holding fuel pressure for the 1-2 min I was told.
Is there still something wrong or would this be normal? To be honest I don't see how it's possible to have fuel pressure for 1 -2 min after the pump been turned off as there is no drain back valves or similar.
