Will high fuel pressure damage the injectors? One day at the track I use the dump I just bought, car was leaning out so I up the fuel pressure. I got it set up at 52lbs (line off) and got a good 02 voltage at WOT at 780. But when I run it through my Mufflers I will have to turn down the fuel pressure to around 48 lbs (line off). Does it mean I need bigger injectors?
