fuel pressure regulator leaking help!
85begalttype
just a v6
i installed a new adjustable fuel pressure regulator and i was checking the fuel pressure with the line off, is fuel supposed to leak where the adjustment screw/line goes onto?
Made by Holley
It was a Holley, it'll be 4 weeks to get a replacement, anyone know any other brands that i can order at an autoparts store in Canada , or do i have to order online?
Grab one from Mike at Full Throttle. You wont find one in Canada. Never had a Holley but the Accufab are rebuildable if needed. I have done mine once & it took about 10 mins from start to finish. Get the ones from Mike as he has 2 choices of them. Most vendors carry them.
PS: It's Bkoken! Broken Real Good! ;) ;)
I found a store that sells the accufab one, only about an 1.5 hour drive so im gonna go with that.
