Fuel Pressure Setting
TURBO2
I see a lot of chips that have a suggested fuel pressure setting. What part of the chip controls this? :confused:
No fuel pressure control is provided by chip. It is the recommended setting.
Most suggest 43-43.5# Vac. Off. Minor adjustments up or down may be made to fine tune.
Joe
brockblackz28 said:
what doe vac off mean?? :confused:
It means when you set the fuel pressure the vacuum line should be remove from the top of the Fuel pressure regulator. It should be re-installed after setting. :rolleyes:
No matter what chip I run I have to keep the Fuel Pressure at about 28# static. The higher I go the worse my throttle response gets and I end up with black smoke coming out the tail pipes if I rev it up. :confused:
That sounds like your injectors are bigger than your chips think they are. What injectors are you running, and what do the chips say?
I'm running the Motron 60# injetors. The chips I have are for 60#. I've experimented a little with taking the chips and changing only the Injector size. I've changed it from 55 up to 65 and I have not noticed much of a difference.
