Dec 10, 2009 #1 B bigbreeze New Member Joined Dec 9, 2009 Messages 4 What should my fuel pressure be with a stock chip and stock boost at idle
Dec 10, 2009 #2 B BRAD_PADGETT Well-Known Member Joined Jan 22, 2004 Messages 3,566 I recall that 39 lbs line off was the stock setting. Somebody please confirm. Thanks-Brad
Dec 11, 2009 #3 W Waco84GN Member Boost-aholics anon Joined May 25, 2001 Messages 772 from gnttype Fuel Pressure (Stock "233" regulator) 34 - 40 psi "static" (Vacuum line removed) Static + Boost pressure Fuel Pressure (T/TA "237" regulator) 37 - 43 psi "static" (Vacuum line removed) Static + Boost pressure Jerry
