SignUp Now!Originally posted by njturbo
22 with line off?? way to low.
Originally posted by Gn-Krazzie
I am running 50 PSI Line ON with a T3/T4B turbo , the chip i believe may be a kenne bell. How closely does the fuel ratio track the fuel pressure. I prefer to run alittle rich to protect the motor and it appears to pull good at this setting. I do get the odd pop now and again which i understand is from a lean condiction.??. I run 15-16 PSI Boost on the street only. I have the stocker pump ( in tank ) and a Bosche In-line Pump which is old school i know. But hey it works have peaked at 20 PSI in certain situations.
What is too much fuel pressure doing to my injectors ?? I am thinking its not affecting the spray pattern just equates to more flow.
Is this odd pop @ WOT lean condition or is an electrical system problem.
